  • Detroit ddec pro driver
    Posted by ed on January 17, 2020 at 10:12 am
    Just picked up a 2nd Detroit diesel pro driver unit. It comes with a 6″ pigtail to a 14 pin connector which 7 pins are used. Wondering where this plugs in to get working ? This Is for a 93xl Liberty. I can’t imagine it’s the j1708 below the driver bay but it’s possible – if that is the case – then I need a 14pin adapter to that. But figure there must be some other connector somewhere that this connects to. Any help would be appreciate.
    Deleted User replied 5 years, 5 months ago 7 Members · 7 Replies
  • 7 Replies
  • Roy
    January 17, 2020 at 6:35 pm
    Yep, pretty sure that’s it and if so you would need an adapter.
  • al
    May 19, 2021 at 1:29 pm
    Any idea why I have no power to the Detroit Diesel display ? It worked prior to changing batteries . Is it fused linked ?
  • darrell
    May 19, 2021 at 1:37 pm
    Is it possible someone left off a wire.
  • Deleted User
    Deleted User
    May 19, 2021 at 1:39 pm
  • Ed
    May 19, 2021 at 2:18 pm
    Reset the breaker on the vertical panel above the engine start batteries. Red button. Inside pass side engine door. Hope this helps. Darrell
    May 19, 2021 at 4:03 pm
    Paul, all wires are on . Need to check the Breakers , thank you
  • Deleted User
    Deleted User
    May 20, 2021 at 6:42 am
    If the breakers in question are the ones located next to the 12v and 24v cutoff then they are all good . Were these the breakers suggested Paul or are there others ?
