Dash / Rocker Switch Lights ?
Posted by Archived on November 25, 2012 at 11:02 amI have lighted rocker switch’s on My dash and Drivers side control panel. And some of the lights are out. Is there a bulb that can be replaces in these Rocker Switches on a 1996 Prevost Liberty ?
Thanks,
Rocky
Archived replied 10 years ago 5 Members · 8 Replies -
Yes, available from Prevost. PITA keeping up with those, but worth the effort because they look good when they are all lit.
Some of my switches are in disuse. I find it’s actually helpful to have those dark at night so I’ve stolen some bulbs from those switches.
Can anyone point me toward a post or article on replacment of the bulbs in the rocker switches ? 2 of us dum dum’s have racked our brains for over an hour in vein trying to seperate the bulb housing from the rear of the switch. I’m sure it must have been documented within the forum here somehwere already. Thank you.
I replaced a lot of them and posted a post about it but you can push an little screw driver in and they will come right out from the back
Peter or anyone, I must be like my dumb monkey avitar because I’ve got a bald spot from scratching my head on how to remove the portion of the switch housing the light bulb. Anybody with a snap shot of where to insert the crow bar would be appreciated.
I’m also looking for a pair of hub caps for my steering axle. I don’t care if they mismatch my others if they are a deal. Strapped for cash at present and need to replace a couple that flew away somehow. My email is bontonjeff@gmail.com Also looking for used tires. I’m in Tampa but can try to retrieve them in othger parts of Florida. Thank you.
Can those bulbs be replaced with LEDs? or just you use incandescents. They get awfully HOT on long runs.
Jeff, the cheap “baby moon” chrome hubcaps for the front axle cost less than $10 apiece at the truck bling store.
could you be a little bit more informative on how to replace the bulbs! small screw driver to remove cover where do pry? have to remove dash? what and where to you get bulbs, please help
Larry Nelson
2002 XLII Vision
Hurricane Utah
