Dash Air Help – Greensboro, NC
Posted by Archived on April 9, 2013 at 5:19 pmI’m posting for Peter…
He’s on the road and no dash air, I suspect low freon. He’s heading for Greensboro and wondered if anyone could suggest someplace to get it checked out.
Peter travels from March to October on business and has to keep moving.
Archived replied 13 years, 6 months ago 13 Members · 23 Replies -
Welch Industries, 650 Red Oak Road, Stockbridge,GA (770) 474-1150
This is not Greensboro,NC, but may be on his route in the future.
JIM
There is no power at back checked C post only 8 volts maybe it is the temp sensor under dash did not jump the relay yet but still no power at back no power at steering bay either it’s not a bad ground what do u guys think???
Carolina Caterpillar has several locations from greensboro west
(800) 277-1212
http://www.carolinacat.com/parts-service/overview.cfm
Here is a group I use for parts , tey have an excellent shop in Raleigh, I suspect it is the same in Greensboro.
5. Fleet Pride – Greensboro
7603 Boeing Drive Greensboro, NC 27409 (800)632-0275 -
I’m confused. Is the problem with the dash air or is there a problem with low DC voltage?
I get especially concerned when folks not used to working on a Prevost are used in desperation. Doesn’t Amadas have a presence within striking distance? Johnson RV?
In your front elect compartment ck to make sure your 12 volt bus has full power.? Might be a supply issue. Does your drivers AC run off main AC compressor or have Aux compressor? Bob
problem fixed no freon it was leaking above drivers seat from line every thing good now recharged AC works great thanks for help went to holiday coach 2000 dollars they work on private coach also Bobby Gordens coach was just there they have 60 H3-45s they no there stuff they do good work
Was just wondering how cold is your dash air? (the temp at the vents)
Left Texas at 5:00 am at 2:00 it was 88 inside dash air on very low it was 75 do not know what temp coming out of vent I will see if I can check tomorrow with temp gun on myway to KC ,MO
David, seems like mine was 55 degrees if I remember right. That was at front vent on my 1991.
Thats what mine is 55 I would think it should be in the mid fortys im useing R134A
Your leak was above the drivers seat ? Were are the lines there? I have a leak have put dye in it but cant find it , have checked all over engine compartment all lines as far as i can see going forward , compressor .,comdenser , and lines going from it also dryer , evaporator it self and lines by enyry step ,d.id not know about over drivers seat was going into spare tire well tomarrow
Mine is 35 at vent on dash with the temp gun on vent The leak was above drivers seat there is a second blower up above drivers it was one of the lines going into it right at blower this is another fan plus I have dash air if there is a leak there will be like streaks of oil on wall or some where it does not leave its like it stains the metal if u can see it good luck my was not to hard to find but I don’t think many techs would have found it the fitting was loose hard to tighten but got it
Peter, did you get it repaired in Greensboro, at Holiday coach, did they take you right in! sounds like a good place since I also am only 85 miles from Greensboro. Gary
I was there twice both times right in once for dash air and for new starter they are great I just phoned them right in within one hour of phone call I called when I was on road took me one hour to get there right in they have about 60 H3-45s they own easy to get to
