Cruise Air Blower Fan Buzzing
I have a Cruise Air that when it’s first turned on, the fan blows on high, and sounds normal, but as the temperature gets closer to the “set” temp, and the fan should slow down, it doesn’t, and as the LED indicator on the fan shows less speed, the fan doesn’t slow down, and it makes a buzzing sound which gets louder, as less fan speed is required.
I can lower the temp, which causes higher fan speed, and the noise goes away…….until it gets close to the setting, and the noise starts again.
Sounds like an electrical buzzing? Any clues as to what to look for?
