  • Coolant/Radiator Fluid?
    Posted by Chas on April 21, 2014 at 8:04 pm
    I swear I asked this and took notes, but I can’t find it anywhere?
    What kind of coolant/anti-freeze/radiator fluid should I be using for the DD S60 and the Kohler Generator? Is a basic 50/50 mix okay? Or is there a special “diesel” version I should be using? Want to put a gallon or so in the bus as a spare/backup and want to make sure I have the right stuff.
    AL replied 12 years, 6 months ago 6 Members · 10 Replies
  • 10 Replies
  • Paul
    April 21, 2014 at 9:33 pm
    Charles,
    I use the heavy duty truck green stuff concentrate and mix my own. Depends on what you have in yours, could be extended.
    April 22, 2014 at 7:09 am
    Forget the color. It used to mean something but not anymore.
    Use only coolants that meet the Detroit Diesel and generator specs. Here is the Detroit Diesel publication on coolants. Keep in mind that cavitation is a serious issue with a diesel engine and the wrong coolant can contribute to engine damage.
    http://www.demanddetroit.com/pdf/vocations/coolant-selections.pdf
    http://www.ccjdigital.com/understanding-coolants/
  • Sammy
    April 22, 2014 at 10:47 am
    Thanks, Will head over to NAPA today and pick up a gallon or two to have with me in the coach (just incase).
    April 22, 2014 at 11:10 am
    Finding an acceptable extended life coolant for the engine is pretty easy. Finding one that’s acceptable to all other components in the coolant path is not as easy. There is one additive that has been proven to attack soldered joints like those found in radiator cores and heat exchangers. I would steer clear of that one additive because you can find others without. The Detroit labelled product would be my first choice.
    Look at this thread: http://prevostcommunity.com/forum/threadDetails.asp?ThreadID=808
    April 22, 2014 at 11:16 am
    One of the things to remember about heavy duty diesel coolant is that it has a change interval that has to be observed. If you do a search on the internet for information about coolants it will show that coolants do far more than help transfer heat. After a period of time in service coolants have to be changed because they no longer function to protect the engine.
    There are extended life coolants which when properly used can extend the change interval, but they also require changing.
    And Tom’s reference to color at one time was correct but almost every color in the rainbow is now available and the old color guidance has been thrown out the window. So we have to verify the coolant spec meets the engine manufacturer’s requirement.
    April 22, 2014 at 11:38 am
    Based
    on DD’s document (Jon referenced), I was going to go with the DDC Powercool or equivalent
    TMC RP-329 TYPE A product with a corrosion inhibitor.
    Wasnt going to plan on an extended life coolant.
    April 22, 2014 at 11:40 pm
    will the cat ec1 work good in 2000 country coach h3-45
    April 23, 2014 at 6:35 am
    Any EC-1 spec coolant will work. However…….the system has to be completely purged of the 2 year coolant. If a coach has EC-1 spec coolant steps must be taken to prevent adding SCAs or mixing inorganic acid technology coolant with the organic acid technology coolant.
    http://http://www.truckinginfo.com/channel/aftermarket/article/story/2013/05/how-much-do-you-know-about-heavy-duty-coolants.aspx
    April 23, 2014 at 8:00 am
    If not mistaken and assuming the CAT EC-1 formulary hasn’t changed, I would avoid CAT EC-1. Although it should be okay in a DD60, it MAY not be safe for other coolant use systems. There is two formulas of EC-1 that have been proven to degrade solder joints. Again, from memory CAT uses one of those two formularies.
    I tried to delete a duplicate post but the delete functions seems to have been removed.
    Working fine. Are you saying when you click on Edit, you don’t have a delete button at the bottom of the page?
