  • coolant leaks
    Posted by Calvin on February 23, 2021 at 9:04 am
    After using my Webasto last week to survive the Big Texas Freeze, I shut everything down only to find several coolant leaks two days later. One leak is behind the driver tag axle and the other is in front of the passenger drive axle – I’m relatively sure I could close all the coolant valves and the leak would go away but that’s not the fix. Also prior to the storm, I developed a lean to the starboard side – last year it was the left……..
    Guess it’s time for another trip to Prevost Houston…….. $$$$$
    Ed replied 5 years, 9 months ago 3 Members · 2 Replies
  • Ed
    February 23, 2021 at 6:59 pm
    Our ’88 had a circulation pump in the rear by the Webasto and another in the front behind the bumper where the Cruiseairs were located (nearly impossible to access). It sounds like you have a similar setup and my just need to put a wrench on the hose clamp connections.
    February 23, 2021 at 8:51 pm
    Cold weather creates more leaks in the coolant system than anything else.
    Get a screwdriver and tighten the multitude of hose clamps.
