  • Coil Sens. Therm
    Posted by Art on August 6, 2021 at 3:21 pm
    Who knows what this is Coil Sens. Therm C1 39 degrees Co 23 degrees and where is it ?,it looks like like a thermal switch of some kind? to the right there is a driver’s liquid valve that’s top of spare tire compartment
    Art replied 5 years, 3 months ago 4 Members · 6 Replies
    August 6, 2021 at 8:27 pm
    Looks like the thermostat for the Webasto bay heat. On at 23 degrees and off at 39.
  • Ronald
    August 6, 2021 at 9:04 pm
    The drivers air liquid solenoid valve has to have a signal to open and close. My understanding of your drawing is that is the thermister that is installed in the coils of you dash unit evaporator and opens and closes circuit to let liquid refrigerant valve operate.
    The refrigerant valve is normally close until it receives its signal.
  • Ronald
    August 7, 2021 at 10:05 am
    Yes it is in the circuit to let 24v in to the switch on dash for compressor clutch and goes through low & High pressure switches. But where is it I wonder?
    August 7, 2021 at 11:52 am
    It is measuring the temperature at your evaporator coils and opening and closing the liquid refrigeration valve. Look in you evaporator for the wires going to this thermistor back to valve. It is showing the temps it opens and closes at on circuit.
    August 8, 2021 at 9:33 am
    Good tip Ed! it measures temp of evap coil does this look like it?
    August 8, 2021 at 10:22 am
    Known as freeze switch. keeps coil from icing over
