co-pilot seat electrical problem
I have a 1998 H3-45 Featherlite. The switch moving the back of the seat was not working. I removed the switch and in so doing must have blown the fuse. Not being sure where it was located i looked at the fuses below the driver side, and found a 15 amp blown fuse at the top of the compartment on the far left of a fuse bank. When i went to replace the fuse the new fuse also blew. To make sure it wasn’t a bad motor on the seat, i unplugged the seat electric and tried to replace the fuse. Blew again. i then removed all the switches that operate an air bag in the seat and raising the footrest, thinking maybe a switch caused the problem. Put in a new fuse. Blew again. Maybe it’s possible i have the wrong fuse, or something else has happened. First, who might know where the fuse is located for the electric co-pilot seat on a 1998 H3-45 Featherlite. That might be the best place to start.
Thank you,
Crownlundy
