    May 12, 2014 at 6:58 am
    The new CAC likely provided the full amount of boost your coach needed. When your old one was leaking you were not getting all the intake air because so much was leaking out of the CAC.
    May 12, 2014 at 7:12 am
    Mark, how high does your air inlet temperature get?
    Unless the radiator fan is on high speed you can expect the air inlet temps to be high. I think EGR engines have an air inlet sensor to activate the fan. If not or you simply want the air inlet temperature to run cooler turn on dash air or do what a lot truckers do and install a radiator fan activation switch at the dash.
    A leaky CAC should not affect air inlet temperature, just the amount of delivered boost.
  • Ron
    May 12, 2014 at 8:28 am
    The new CAC did not make any difference in engine temperature. I didn’t hook up the iPad this trip so I don’t know what the inlet temps are. The fan is working, we tested it while at Prevost TN working on the a/c and checked both speeds.
    I had one inlet temp code and a couple of “special instruction” codes on the way back from TN. Neither turn on the CEL, and both can be cleared. I have seen these since I got the coach. All depends on outside temp and if you are pulling any big hills.
    May 12, 2014 at 10:26 am
    I’d like to make an attempt at answering some of these questions.
    G-Man “Was going to
    start another thread but hope its ok to piggyback on this one.
    I was able to play around with the DDEC pro
    driver a little bit, but am wondering is there another way besides a Scan Gauge
    D or using the iPad app for the RV dash to get good ECM data and clear codes?
    I assume there is no
    OBD port, just the J1939 interface?
    The round black 9 pin Deutsch connector has J1708 and J1939 communication
    lines. The round gray Deutsch connector has only J1708 communication. These are
    the OBD ports for us and the heavy truck industry. The communication protocol is
    different from the automotive / light truck OBD II. You can use the factory diagonstic software, DDDL to mointor most any engine parameter you can think of.
    Do the 2000 up Prevosts
    give you EGT’s or do you need to install a pyrometer if you want to feed that
    data to the ECM? ( or can you feed it to ECM?) “
    Detroit does have an option in the program for an EGT sensor. I’ve never seen
    one installed on anything from the factory, but it does exist.
    G-man “Thanks guys, I
    am looking towards the future in regards to EGT, I realize on the stock tune
    with the Detroit you can probably not hurt anything but I am considering adding
    power later to increase MPG as I have done I on my current rig.
    Right now I use an old
    Edge tuner to monitor boost, EGT, ECT, and % of load. I tuned it with EFI Live,
    picked up over a MPG adding around 60 HP but in certain situations like big
    hills you need to back out of it as EGT’s will get up there. Especially when
    towing heavy.
    I don’t recommend anything over 10% more fuel than the
    stock setting unless you have some type of EGT gauge. Most of the diesel tuners
    say 1200 degrees in the exhaust manifold before the turbo on your longest
    hardest pull is a safe number. All 4 stroke Detroits I have seen are set to
    warn the driver when the EGT reaches 1050 degrees by turning on the CEL,
    derating or stoping the engine (depending on programming) that is if the EGT
    sensor option is activated. I think Jon has tried to find an offical document from Detroit that states maximun safe EGT but so far it doesn’t exist.
    Gil I saw your setup
    and looked at the SilverLeaf site, that may be the solution, I liked how you
    have the ability to do multiple things in your dash, like back up camera etc.
    I wanted to use
    somthing like Torque for Android but they do not yet support J1939, Silverleaf
    does but with Windows…my hope was to maybe mount a tablet and have it do
    multiple things, monitor gauges, GPS, and dash cam, looks like this may work
    with a Windows tablet and VMSpc from Silverleaf!
    Busman
    Have silver overlay does not show Egt shows torke”
    Silverleaf does not have the option to read EGT’s or
    least I can’t find it. Everything that the Silverleaf reads are standard requirements
    determined by the SAE. There is much information on the 1708 or 1939 CAN bus
    that is manufactory specific and only their software will decode the other information.
    For example Detroit’s diagnostic software DDDL will read EGT’s, VNT vane
    percentage and injection timing. Silverleaf can’t do that.
    travelite “Our pre-EGR S60’s don’t use
    J1939; we run J1587/J1708.
    I’m sure you’re referring to what is available at the diagnostic
    port but just to clarify. DDEC III was
    introduced in 1992 or 93 I think and the later software levels had J1939 communication
    available. DDEC IV up all have j1939 communication protocol.
    Gil_J “I think EGR engines have an air inlet sensor to
    activate the fan”
    I’m not sure if DDEC II had an air intake
    sensor, but from DDEC III up all the four strokes I’ve seen have an air intake
    sensor. The point at which the ECM requests the fan to activate varies with application
    and engine type. Silverleaf can monitor this sensor.
    Gil_J “A leaky CAC should not affect air inlet temperature,
    just the amount of delivered boost”
    I think a leaky CAC cooler would affect air
    inlet temperature. At 43 lbs of boost on a hard pull I’ve seen 500 degrees on
    my turbo outlet side. Some of that temperature comes from the pressure. If my
    CAC was leaking enough where I was only to produce say 30 lbs of boost the
    turbo outlet temperature would drop
    which would drop my intake air temperature.
    Mark3101 “I see the inlet
    air temp to high sometimes when climbing bigger hills. Seems to be common
    with our setup. The folks at Prevost said not to worry about it and my
    Detroit dealer didn’t seem concerned either. I just clear them out”
    EGR engines can run really high intake
    temps because of the exhaust gas being dumped in the intake even though it’s been
    run though the EGR cooler.
    Mark3101” Hope your VPOD works ok as I went through 3 reman units
    last October to get one that works…I was sitting at a Detroit dealer for
    almost 2 weeks for them to finally find and fix it.”
    All of that VPOD, VNT and EGR pain can be eliminated.
    I’m reasonably sure all this information is
    correct. If anyone has better or additional information please post it.
    Thanks,
    Ken
  • Ken
    May 12, 2014 at 11:05 am
    Silver Leaf can collect any message data transmitted over the data link as long as you know the message identifier. When you select a specificspecific engine they select the standard messages for that engine. You can change or add to that list.
  • JIM
    May 12, 2014 at 11:08 am
    I haven’t use Silverleaf very much. What type of identfier is it asking for? Like a hex address or PID?
  • Ken
    May 12, 2014 at 4:37 pm
    Great info Ken, thanks!
    May 12, 2014 at 6:59 pm
    Ken, you need the PID to log data that isn’t being read for the engine selected. You can also change the default PID for any reading.
    May 12, 2014 at 10:03 pm
    Gil, could you give me something that the Sliverleaf doesn’t read that
    you would like to see. For example fuel temperature or can you already
    monitor that?
    If anyone with DDEC V using Silverleaf would
    conduct an experiment for me. If it’s not already monitored, the TCO (turbo charger outlet temperature)
    I think the PID is 404. Set that PID up in your Silverleaf and let know
    if it reads the TCO temp..
    Thanks,
    Ken
  • Don
    May 13, 2014 at 9:13 am
    Ken, I am sure it’s out there somewhere I can get the exhaust temps on any Detroit engine up to 2000 my book even has temps for the 2000,1000,3000 plus the 100,200 and 500 series which were Perkins engines rebranded as a Detroit Those are hot running suckers from a 1000 degress to 1255 degress fwiw
    May 13, 2014 at 1:54 pm
    Clifford,
    After seeing 1050 set
    as the default from Detroit to set a check engine light I feel good about using
    1200 degrees as the maximum. Usually their numbers are conservative and I actually
    try to keep mine at 1100 max just in case of a very hot day or I’m not paying
    as much attention as should to the gauges.
    Ken
    May 13, 2014 at 1:57 pm
    Ken,
    This Silver Leaf document might be helpful. It has a PID sniffer so it should be able to automatically detect all routinely transmitted messages. So far, I haven’t seen a need to add any that aren’t already defined for my engine. I did have to add some for my last CAT powered coach and that worked as advertised.
    http://www.silverleafelectronics.com/sites/silverleafelectronics.com/files/VMSpc25%20Manual_0.pdf
    May 13, 2014 at 2:45 pm
    1200 is a little for a 2 stroke one really has to push it for one to go over 1000 degress,where as the emission engine were built to use higher ETG it has been that way Europe for years the higher EGT the lower emissions I was told at a Detroit class. I checked a series 60 with CNG that pupply was 1300 F @ 1800 rpm I see why they don’t have cast manifolds
  • JIM
    May 14, 2014 at 9:57 am
    Thanks Gil for that link. I’ve been using the diagnostic
    software on a laptop to view the parameters and my intent was to stop using it
    once I was convinced my regular analog dash gauges were reading correctly. But now I’m hooked on the other information
    available on the diagnostic software. The problem is there are no options for
    gauge styles or size with factory software. So I think I’m going to integrate a tablet somewhere in the
    dash with the VMSpc.
    Ken
    May 14, 2014 at 1:01 pm
    Ken, it might be easier to bury a laptop somewhere and just extend a remote display screen. That would give you more options. FWIW, when I was running VMSpc on my dash I had a split screen with Microsoft Streets on the other half of the screen. That worked well.
    Now I have their glass dash and love it!
Page 2 of 3
