  • City Water
    Posted by Thomas on July 6, 2020 at 6:47 pm
    On our first major trip since buying the coach in Feb. I have forgotten how to connect and use city water. I connect water hose to “city water” connection but still end up using water via pump from from our tank. I don’t remember if there is a valve or switch I need to use to make this work properly. I have a valve to allow water to fill tank, but can not figure out how to keep from pumping from the tank.
    Update:
    I have city water if I turn off headhunter pump (toilet does not work then!). I have 12V pump water if I disconnect city water and headhunter pump off (toilet does not work). If I have headhunter pump on, I use water out of the tank.
    Update2:
    Headhunter pump has a gauge reading cut in at 72psi out at 92psi. Thinking this could be restricting city water from entering bus and therefore using headhunter pump. Ideas? Is a headhunter pump adjustable pressure?
    Thomas replied 6 years, 4 months ago 1 Member · 0 Replies
