Chassis Heat Issue
Posted by al on January 21, 2020 at 10:38 amGood morning , On a recent trip I was unable to provide coach heat to the cabin . I had dash heat , however I did not have heat throughout the cabin . I did have heat on a previous trip one month ago but not this trip . Any thought on where to start looking ? Thank you in advance .
Dick replied 6 years, 9 months ago 9 Members · 9 Replies -
To clarify I do have Aqua Hot heat and tow kick , but not coach heat . The Prevost heat from the OTR system . Sorry for the confusion .
Al, Just to clarify, are you saying you are getting heat at the dash, but with the OTR turned on you are not getting heat in the rest of the coach?
I have the same issue in my 1984. It has been suggested that I rebuild the main water valve by the heater core, but I haven’t gotten around to that yet. They can apparently get gummed up and stop opening when it calls for heat.
Jon , That is correct . Not sure if connected but 2 months back I had the same issue on the Air condition side . I dont see how they could be connected as one is water the other Freon . Any ideas where to look and thank you both for the rply .
Well we have an appointment in the morning at Prevost in Jacksonville and will post the repair and cost .
Well after our trip to Prevost in Jacksonville all is well . Turned out there is a 12v wire running from the alternator that was burned . The wire runs to the relay in the front which controls the OTR heat . It did take 2 hrs due to the fact the wire was burned on the back side .
I had no issue with it taking that long because the repair also fixed another issue we had with a battery dash light . It seems we originally thought we had a imbalance issue , however after replacing the Vantare installed voltage balance we still had a issue with voltage readings . Well Paul our Prevost technician said this will take care of you dash light also . So all is well and our experience could not have been better . Thank you to all that offered help .
It was not protected and was sitting on the alternator . So after the splice he covered it with wire loom .
