  • Chassis charger
    Posted by Peter on December 9, 2016 at 1:39 pm
    If anybody has the Guest pro charger mine is a 2620A. , I never use it but was new in 2014 turned it on when I bought the coach it was new then , so went to check it out and I turned it on and the lights came on but 3 mins after all was dead , so I checked the power it was good , marinco said that if they sit for to long the gel in the resistors settles and when you turn it on it shocks the gel and it burns out so unit is no good they said to turn it on every 3 months just to check it out and keep things working , they sent me a new no charge but it’s updated more than the old one which was only two year old the new number is Marinco 28220 it’s a direct replacment for the 2620A same mounting holes and all, hope this helps somebody, would be bad if u never use it and then u needed it and it will not work , I never use it unless I am working on the lights or something on the chassis my batteries sit for 3 months and stay charged right up so no neeed to turn it on ,
    So check them out guys
    Peter replied 9 years, 10 months ago 1 Member · 0 Replies
