  • Chassis Batteries – Caution
    Posted by Archived on July 31, 2018 at 9:10 pm
    Be careful around your chassis batteries and never have your head in there when someone turns on the ignition.
    This happened a week or so ago at Jeff’s and sounded like an air bag explosion. No one was near the rear and I believe all Jeff did was turn on the key and whamo.
    Dick replied 8 years, 3 months ago 6 Members · 6 Replies
    July 31, 2018 at 9:17 pm
    What the hay caused that? Gremlins or Russians??
    August 1, 2018 at 8:07 am
    That is typically caused by a broken cell connector inside the battery. A load is put on the broken connector sparks in a explosive gas environment. All this happens inside the battery. Things go boom…
  • Darrell
    August 2, 2018 at 10:27 pm
    Happened to me.
    What a mess to clean up. Batteries were 4 years old. I now make sure that each time I start the engine, I turn the ignition switch to the first position, wait for all the relays to click, then turn to the start position. So far, so good (plus I replaced all batteries).
    August 3, 2018 at 7:18 pm
    Happened to me last year on chassis bat only turned on ignition no starter
  • terry
    August 3, 2018 at 9:10 pm
    How many of you that had a chassis battery burst also use a battery maintainer or trickle charger? Be honest.
    August 3, 2018 at 11:10 pm
    My guess is with Jon, they had likely been on charge and were gassing.
    The batteries in the picture are over 6 years old, my guess would be that they had more than one weak cell at that age. If they make it to their 5 birthday I would replace them just from a reliability standpoint.
    Just my 2 cents
