  • Center section of rear bumper
    Posted by Gerald on April 1, 2013 at 10:11 pm
    One of the previous owners put a couple of 2 inch dents in the center section of the rear bumper. It would be nice to replace that section.
    Question: If one orders a replacement from Prevost (#410583 $600) does it come polished from the factory?
    Gerald
    Peter replied 13 years, 7 months ago 3 Members · 2 Replies
    April 2, 2013 at 6:28 am
    Gerald,
    If you are a little patient and have a few tools you can remove the dents. I had a substantial dent in the bumper on my previous coach and I pushed the worst of it out using my hydraulic jack and the weight of the coach by jacking under the hitch pressing most of it out.
    Then I used a small belt sander to smooth the irregularities that remained after jacking and beating the dent out. That left me with a bumper that was back to the original shape but with an unpolished belt sanded area. I had used about 80 grit on the belt sander. I then used a disc sander and went from 120, to 220, to 400, to 600, to 1000 and finally to 1500 grit sanding discs. I then did a final polish using white rouge and a buffer.
    I could see the area that was repaired, but unless I told others how to find it nobody knew the bumper had been repaired.
    The bumper is heavy enough to allow you to make a lot of mistakes while you are learning and working it unlike the skins which are much less tolerant of attempting repairs. Take a chance and try it. You have nothing to lose. If you succeed you will learn the basics of a skill that can then be applied to repairing rub rails and then as the skill develops you can hide minor damage on certain skins.
  • Georges
    April 2, 2013 at 10:27 am
    Jon,thanks for the tip. I’ll have to try that. If I screw up I can always replace the section.
