  • Ceiling Lights
    Posted by Darryl on September 4, 2022 at 6:47 pm
    I have a 2002 marathon. One of the LED ceiling lights in the galley started flashing. I tried to replace it, like I have several other places in the coach, but the bulb I replaced is dim and the one next to it doesn’t work until I unplug the first one. If I pull an older one from elsewhere in the coach and use it in the first socket neither work. If I replace both with new ones they are both dim. I have used these bulbs in other sockets thru out the coach with out issues. The voltmeter show a little over 6V at the socket. What have I done to my couch?
    Thanks for the help.
    Art replied 4 years, 1 month ago 9 Members · 9 Replies
  • 9 Replies
  • Tom
    September 5, 2022 at 7:45 am
    Try to HOLD the button down and see if they are in the “dim mode”.
  • Marshall
    September 5, 2022 at 6:17 pm
    Daryl, go back in the closet and pull back the cover, probably curb side. You will probably see a red light on one of the fuses, that’ll be the problem. BTDT
  • M Keith
    September 5, 2022 at 7:47 pm
    Thanks Mike and Dan. I’m out of town but will check it out when I get back to the Coach.
    September 18, 2022 at 10:36 am
    I replaced the fuses in the node, they weren’t blown. No change.
  • Deleted User
    Deleted User
    September 19, 2022 at 7:39 am
    It sure sounds like you have a bad ground somewhere in that circuit .
  • Chuck & Katrina
    September 19, 2022 at 8:40 am
    Darryl, the fuses I referenced are not in the node. They are in the long bank of fuses in the closet, when the circuit is on if the fuse is bad a red light will be on. Good luck.
    Leesburg, FL
    September 20, 2022 at 5:09 am
    Dan, I did check those fuses as well and the circuit breaker in back closet. All OK. Sorry I didn’t say that in my reply.
    Paul, That is what I will try to chase down next. Thanks
    Darryl
  • Joe
    September 20, 2022 at 7:11 am
    Darryl if you remove all the bulbs in the circuit take a meter and check voltage at each socket ,then give meter a separate ground see if different. Then add one light into circuit and check voltage if low give circuit a good separate ground.
    September 20, 2022 at 7:12 pm
    Well, rats….was hoping that was the issue.
