  • CB antenna mounts?
    Posted by Archived on March 19, 2013 at 10:19 pm
    I have two tear drop mounts on the side of my 98 Liberty a foot below the roof line , just above the drive axle tires. They look like the Firestick side mount CB connections as below. Can some one confirm that I am correct?
    You can see the dark spot on the view below. There was no antenna in either mount but I would like to put some there for both CB and NOAA weather .
    Archived replied 13 years, 8 months ago 1 Member · 1 Reply
  • 1 Reply
    March 20, 2013 at 6:26 am
    Wave,
    Liberty used twin CB antennas mounted where you describe. There a couple of things to note about that location. First, I never had much luck with those antennas no matter what type. Fiberglass, steel whip, or whatever. Poor reception and transmission. If you do mount antennas there I suggest you install a spring base so they can deflect unless you can keep the height to 13’6″ from the ground. Get antennas you can tune to get the best performance.
    My final solution was to get a no ground plane small wire antenna that I located above the driver’s seat on the top of the front cap. I could tune that using the meter by adjusting its length and it worked better, although still not great.
