Carpet Question
Posted by Dennis and Mary on July 7, 2015 at 12:00 am
Can a carpet be put under the slide-out?tArchived replied 11 years, 4 months ago 4 Members · 4 Replies -
Sorry, for adding the X to the title. Nobody could access it until I gave it a title.
To answer your question I have to ask a question. Whose slide? Different slides have different configurations. A Prevost slide will go over the top of carpet. If you are redong the carpet or flooring however it can go under only as far as the installer can slide it unless you remove the entire slide room.
I should have done that after I got the post to show up.
A note to all……..if you do not add a title you post can end up in cyberspace and nobody can open it. If Tom or I do a little detective work we can find it and then add any title (such as the X I added) which will make the post accessible. But it is a little bit of work and if we are loaded with other admin work we may not have the time so please check your post when creating a new thread.
