  • Cargo Door Strut in Aqua Hot Compartment
    Posted by John on September 10, 2014 at 10:23 pm
    Had a tip break off one of the struts for this compartment on the H3.
    Figured I would just replace the whole strut and ball ends. Save the rest of this one for parts
    Cant find a replacement on line anywhere. Anyone know where to get one or a source to cross reference?
    Info imprinted on the removed strut reads:
    STABILUS
    LIFT-O-MAT
    279872 0935N 196/13 A 5
    980030
    Michael replied 12 years, 2 months ago 6 Members · 6 Replies
    September 10, 2014 at 11:28 pm
    I bought mine from Prevost. They have them. PITA to change without a homemade tool to release the old Ball/rod end towards the inside of the bus.
  • Sid
    September 11, 2014 at 3:51 am
    What kind of a homemade tool? I sure would like to have one.
  • Michael
    September 11, 2014 at 9:47 am
    I just did 4 on mine and got them at Prevost. You need 4′ arms…..
    September 11, 2014 at 11:00 am
    John,
    I posted a picture of it on here a while back. Basically, it is an awning pull rod, that is slightly bent, and tapered on the end of it. I did that with a vise, then ground it to a point, so you can reach in there to release the clips on the rod end of the old struts, or gas shocks.
    That’s the hardest thing to do, once you get those off, the new ones will just slip on. Then to get the end on the door, the strut may appear a little long, so I loosened the ball stud on the bracket to give it a little extra length, slipped it on, and then tightened the ball stud back up.
    Sorry, I don’t have pictures with me.
    John, just found my previous post…………..search for “Tool to replace bay door gas shocks”
    September 11, 2014 at 11:38 am
    Called prevost this morning and set up my account.
    The guy that helped me knew the P/N Immediately so that tells me this is a common part to fail. Strut was 27.89 each with free shipping so that was a pleasent surprize.
    I did luck out though. The tip that broke was on the end that attached to the bus. When it broke, it did so in pieces and literally fell off the ball.
    Thanks for all the responses and advice.
    John
    September 11, 2014 at 11:40 am
    Get ready, you will have others to get weak, and make the doors hard to lift, or not stay up!
