  • can i remove heater blower,heat pump
    Posted by james on January 18, 2016 at 8:53 pm
    hello again well i removed my ac side on a 1988 lemirage coach bus.sold its motor only to have heat side
    motor acting up now with bearings and brushes .this is 27.7 volt motor can i put in a furnace for heating coach.instead of that unit can i replace it and the pipe with a propane furnace.and will the radiator kool motor with the valves closed and this heat pump removed .please input needed thank you
    james replied 10 years, 9 months ago 1 Member · 0 Replies
