Cabinet door catches
Posted by John on February 25, 2019 at 6:43 amAnyone have a lead on a source for these catches.
Archived replied 7 years, 8 months ago 5 Members · 6 Replies -
They are Southco Latches. Available in 3,5 and 10 lb pull tension.
They can be found on Ebay, Amazon for the least amount of money. Most RV places carry them as well.
There are couple of versions, one is made by Camp N’ and should be avoided as they are really cheap and fall apart quickly. I will be sure the next set I order (usually in batches of 8 or 10) I will make sure they are labeled Southco!
I have also used the same catch your 2 nd Pic . You will notice some replacements are deeper and do not work .
Thank You for the lead. I couldn’t read the tiny letters on the part for a name.
Uglyfishinc.com has been a good source for me in the past and the only place I found white. Make sure you are ordering the correct strength, the difference is very noticeable.
