  • bumper blade measurement
    Posted by Archived on July 7, 2015 at 10:27 am
    I need center blade measurement on a XL. I bought a salvage shell /no rear bumper. I bought one later but with corners on it is about 5 inches to narrow. Trying to figure out if it is blade or corners that are off. Thanks Bob
    joel replied 11 years, 4 months ago 3 Members · 3 Replies
    July 7, 2015 at 7:53 pm
    Bob You might have gotten one from a 96″ wide coach Darrell
  • joel
    July 8, 2015 at 9:20 pm
    Bob:
    For what it’s worth, on my ’87XL, 102″ wide, the rear bumper center section is 74″. It has rather long corner pieces, with 2 small holes in the end which wraps around the side of the bus, as well as whatever bolts them on and to the center section. I should have taken pix.
    The front bumper, center section, is longer: 82-3/4″, with shorter corner pieces with no holes other than for 2 carriage bolts which attach them to the center section.
    Due to the difference in years, yours is probably waaaay different. Good luck.
    Ted.
  • Chris
    July 8, 2015 at 10:18 pm
    apparently that is what I have . measures aprox 83. It is now decision time. easy would to locate rear corner pieces and cut blade to match. O well life is a adventure. Thanks for come back! Bob
