  • Brake sound
    Posted by Eric on March 8, 2020 at 5:41 pm
    For some time now, our brakes make a horn sound when the air releases from releasing the brakes. We refer to it as our clown horn. A prevost tech said our brakes are fine and “some older coaches do that”. That may be true, but we don’t want it anymore. I did not see a way to upload a video with a video of the sound, but I did attach a picture of the part I believe creates the sound. What is this part and will replacing it fix the sound?
    Archived replied 6 years, 6 months ago 7 Members · 10 Replies
  • 10 Replies
    March 8, 2020 at 6:04 pm
    When you release your brakes the R-12 or R-14 valves are releasing the pressure that had applied the brakes. As that pressure is released it makes a noise. Normal.
    The only alternative is to find out which relay valve is making the music, and then start swapping different brand valves to see which one make a noise you like.
  • Gerald
    March 8, 2020 at 6:58 pm
    The noise is not just air releasing. It truly sounds like a horn and then pulsates on and off, from loud to softer until you can’t hear it anymore.
    I don’t hear this from other buses?
    March 8, 2020 at 8:12 pm
    Perhaps you could upload a youtube video and post a link or title.
    March 8, 2020 at 9:51 pm
    I have that “clown” noise too. It comes from the treadle valve when releasing the brake. Air gets released through the exhaust port. There is a plastic shroud around the exhaust port to prevent dirt from entering. That is probably what we are hearing vibrating. I think it is normal.
  • Marvin
    March 8, 2020 at 10:23 pm
    It looks like a Bendix Quick Release Valve. See p.28 of this 116 page pdf file: LINK
    There’s a bunch of different valves, but there is just 1 maintenance kit, # 104463.
    Call Prevost Parts, they should have the correct one, or cleanup your old valve and find the original pt#.
    March 16, 2020 at 5:12 pm
    I changed my Quick release valve up front a couple of years ago (Bendix) and the R-12 for rear brakes and R-14 for E-brake and all Bendix and Pedal valve and it always sounds like a duck sound but it is quick it does not linger on. It started on HWY 20 a logging road and the front brakes weren’t releasing rite away the duck sound had a couple of second delay so I changed the front Quick release valve 1st and it did not fix the problem so I replaced thepedal valve and problem went away. I replaced the relay valves R-12 and R-14 just for maintenance reasons.
    March 16, 2020 at 8:08 pm
    I have ordered a new quick release valve. Where is the “pedal valve”? Do you have a part number? Thank you for the responses.
    March 17, 2020 at 10:20 am
    The Pedal valve is in the steer compartment easy to get to the old valve was a Bendix # 109174 E-15 as per Prevost part changed to Bendix # 800632 E-10 had to use top part of old valve just a metal swing part that pushes piston down, mark all lines before removing take pictures. old on top new on bottom.
    April 21, 2020 at 9:10 pm
    I’m just posting the solution to my “clown horn” was as simple as putting on a new quick release valve.
    April 21, 2020 at 10:30 pm
