  • BRAKE PRESSURE LOSS
    Posted by joel on June 12, 2023 at 5:27 pm
    Just shooting in the dark but someone may have had this issue.
    When I shut off the engine with brake pressure normal and parking brake set, both primary and secondary brake pressure tanks proceed evenly to 0 in about 20 minutes.
    Any guesses?
    Archived replied 3 years, 4 months ago 5 Members · 5 Replies
    June 12, 2023 at 6:40 pm
    I’d check the PP-1 valve first. I had a similar issue. Just by releasing and reapplying with authority, the bleed down stopped on primary for me. I haven’t replaced the valve, yet. It might of been more of user error for me.
    June 12, 2023 at 7:37 pm
    Maybe Bendix R-14 brake relay valve, p.47:
    https://www.bendix.com/media/documents/BW1114QuickReferenceCatalog.pdf
    and my rebuild w/pics
    /threaddetails.asp?Category=Pneumatic%3E&ThreadID=6143
    Bad/fast enough you should be able to here it?
  • Andrew
    June 14, 2023 at 4:50 pm
    Thanks for the replies.
    Went to check out bus this am. Yes, you’d think I’d hear a leak of this magnitude. Crawled around under bus for about 20 minutes with my spray bottle and couldn’t find a leak. Went up front to see if there was any pressure left in brakes and both tanks were still at about 70 psi!!
    I’ll figure it out eventually.
    June 17, 2023 at 1:34 pm
    That’s still a pretty good leak if it’s going from 120 to 70 in 20 minutes.
  • Kelven
    June 18, 2023 at 8:31 am
    What is the aux air pressure doing? If t is dropping, the check valves on tank 1 and 2 as well as the protection valve at the aux tank could be bad. If it is holding ant the tanks 1 and 2 are dropping, then check the parking brake valve, the treadle valve.
