Brake Air Tank Check Valve
Replacing an old leaking push to connect fitting on one of the brake air tanks. It is attached to a check valve 90 degree elbow 1/2 npt by 1/2 npt female. Anyone have any information on it’s part number and or source? The check valve was not leaking, but definitely looks to be original 1999. I have learned the hard way not to reuse any plumbing if you don’t have to.
Thanks in advance to all.
