Block Heater
Never used this block heater before, I did plug it in and I could hear it sizzle a little bit, Is that normal? It is set up to plug it in with an extension cord through the access hole that uses a key on rear upper back of coach where you add oil to reserve. I would bet it pulls 10 amps or so since it has a 15 amp plug. Are block heaters ok to use. When it has not started in a while and it’s cold out probably would be better to warm it a little??
