  • Belt tension adjuster-part number
    Posted by Jacky on August 10, 2015 at 3:01 pm
    trying to find a part number for the serpentine belt tensioner. Gave the ro# to Detroit shop and they said, can’t help you. I am sure there is a NAPA or other part number for these rather than having to go through Prevost. Maybe Jeff or one of you experienced guys can help. Any help appreciated.
    Ken replied 11 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • joel
    August 10, 2015 at 3:04 pm
    I got mine at a Detroit shop, only thing I had to give them, was the motor serial # which is located on the back of the bus, along with the date of the chassis, or at least mine is.
    I’m not around my bus, or I would give you the part number.
    August 10, 2015 at 3:56 pm
    Purchased one from Prevost on 7/20/15. 4″ air bag, part no 550840, $44.95
    August 10, 2015 at 4:27 pm
    This may be a prevost only part as the belt/pulley/fan configuration on most trucks may be different. Also, I believe the early type had a screw tightening the pulley while the later type is spring-loaded automatic.
    August 10, 2015 at 5:27 pm
    JD,
    Are you talking about the big belt tensioner that you use 3/4 breaker bar to relieve the pressure in order to remove the belt?
    August 10, 2015 at 5:43 pm
    Yes the large serpentine belt that has the tension adjuster located on the front of the engine.
    August 10, 2015 at 6:19 pm
    Dayco Gold #89417
    August 10, 2015 at 10:42 pm
    Here is the Dayco replacement used on 05 Marathon XLII. # 894
    I would have to research this out again for using this part number. I think it was the belt pulley width and
    manufacture stamping on the old through Dayco tech service.
  • Ken
    August 11, 2015 at 8:10 am
    Thanks to everyone for the input. Great site here.
