Bay doors won’t lock with switch.
Posted by Archived on November 26, 2014 at 5:33 pmI tried to lock the bay doors with the switch, I hear a relay clicking but the bolts will not throw. I can put in the key and lock them manually but they seem to be tight when I turn them. It don’t feel as the key would break but it is tight. Could it be a lub issue or what should I look for.
Steve
Archived replied 11 years, 11 months ago 7 Members · 14 Replies -
Steve,
It’s a common problem with the lock mechanisms, they are hard to activate even by hand with the key and usually become gummed up over the years from lubricating. This is assuming your latching relay is working and all the door motors are getting power. You have to work on them one door at a time. When I had Tim’s bus, I had to replace all the motors.
Jeff may offer a suggestion as well.
Check the bits of rubber behind the door handle. If they are missing or compromised, the door handle will not align with the bolt such that the electro magnet cannot overcome the resistance, while your manual pressure with the key does.
Tradewinds Coach
Kyle Bennett (Service)
Brian Miller (Sales) -
bay lock actuators are a common problem. Whether it’s one or multiple bay doors it seems like almost all owners fight the tell tale light. If bay doors worked prior, it would be odd that all locks got jammed or quit at the same time. is this a new problem for you – and just to clarify are none of the bay doors locking electrically? If you lock all doors manually and electrically try to unlock bay doors do they trigger or all remain locked? May have cut a wire somewhere.
-Kyle
One thing I have experienced is that the bay door lock actuators are sensitive to low voltage. A quick and easy and cheap attempt to isolate the problem is to replace the relay(s) with a new one and see if that cures the problem. As the relays age you get a little resistance across the contacts and is seems to be enough for the bay door actuators to fail, usually not all, but some.
In your coach the relays are in the second bay, drivers side, probably on the left wall. Have someone activate the bay door locks and if the relays are like the ones on my 97 Liberty you will see the spark between the contacts as they are actuated. Or you could call Liberty and they will tell you where the relays are on your coach.
In my case, I pulled the door panels, lubed to lock mechanisms, and removed 2 over-center levers and springs from each lock assembly. They will move much easier this way and still stay locked or unlocked even without the levers.
I found the relays on the diagram under the driver window. There are several P&B and Bosh relays in a row. The diagram shows the relays for the “luggage doors” but the lines are dotted showing the outline of the relays and the relays are not in the compartment. The space where it shows they are is empty. I looked in the fuse box on the drivers side second bay and didn’t see any relays that looked like the little black square ones in the front under window compartment. There is no diagram for the big pannel in the second bay. It has a clear lexan cover but no diagram. Someone here said the learning curve was steep!! 90deg I would say! All those wires look like malaria germs under a microscope!! Would you know where I could look for the diagram for the second bay pannel?
Do u have the Prevost electrical drawings for your coach? They are available on the Prevost web site under technical publications and will show all the wiring details .
Just remember that Liberty may have changed the supply voltage from 24VDC to 12VDC.
On the site they will ask for coach # put in V and then last 4 #’ of Prevost serial #
Would the last 4 # of the serial number the last 4 of the vin number?
Your bay door relays are in the Liberty electrical bay. My early vintage had octagon base relays but yours is a later model so Liberty may have used a different type.
I don’t even know if that is the issue, but it was on my previous coach. Maybe someone with your vintage Liberty can describe the relays and their location. I know they were on the left wall of the electric bay, a pair of them side by side. I had an Elegant Lady and that relay configuration may be different if you have a Classic.
I found the relay location diagram in the electrical compartment under the drivers window. It shows the two relays in that compartment but they are not in there. I was looking for the little cube relays but I will take a better look. The bay relays are drawn with dotted lines, so that may be telling me they are somewhere else..
On a Liberty they are NOT associated with the Prevost wiring.
