  • Bay door latches
    Posted by Bill on June 10, 2022 at 5:50 pm
    My ’98 CC has push button luggage door lock/unlock buttons. All the bays lock perfectly but one of the bay locks will not unlock unless I use the key. I have tried various lubes and lube combinations but it just won’t unlock. If there a replacement for the drive motor (magent?) that causes the locking bar to slide back and forth? Any other suggestion that has worked for you?
    Thanks.
    David replied 4 years, 2 months ago 9 Members · 8 Replies
  • 8 Replies
  • Mike/Lisa
    June 11, 2022 at 11:33 am
    Following. Same problem on our 99 XL45.
  • Tom
    June 11, 2022 at 4:16 pm
    Ditto- All but one works well. Lubrication didn’t help, thought it might be an alignment issue, but it seems to line up well.
    Could it maybe an air issue, a leak causing not enough pressure to build up and engage and disengage?
  • Michael
    June 12, 2022 at 8:39 am
    These are electric “motors”. Don’t understand why the one locks perfectly but will not unlock.
  • Chuck & Katrina
    June 14, 2022 at 5:48 pm
    This is not a “cure all” but it seems to help. (I believe I’ve had to replace one of my motors.) If you dissassemble the mechanism, you will find 2 levers/springs which cause the locking shaft to snap into it’s final position. Unfortunately, these seem to caause an initial resistance to movement of the locking shaft. Removal of these lever/spring conbinations seems to allow the locking shaft to move more easily.
    Leesburg, FL
    August 15, 2022 at 11:49 am
    I took another shot at trying to get the locking mechanism to work in both directions. While Janet pushed the lock and unlock buttons I used a continuous spray of WD40 and wiped some residue on the lock bar. Did this a couple of times and now it’s working again just like new! I will need to keep an eye on this as WD40 tends to attract dust, but for now, all is well!
  • Mike, 92 Country Coach
    August 15, 2022 at 7:34 pm
    I replaced two of these Actuators on my bus
    Prevost #780428
  • Paul
    August 16, 2022 at 8:49 am
    Bill:
    I was warned by a locksmith to never use WD40. He claimed they designed it to have a varnish like substance in the mix so it lubricates at first, then it dries out, gets sticky and requires more WD40 to lubricate it. It becomes a never ending cycle.
    Don’t know if this is true, but it seams to represent the results I have gotten when using WD40.
    Chuck
  • David
    August 16, 2022 at 10:53 am
    WD-40 is not a lubricant although most people think so. Use PB silicone or Amsoil heavy duty MP (metal Protector.
    PB blaster is the best rust penetrant . I have multiple cans at any one time.
