  • Battery Replacement Shutdown Procedure (Liberty)
    Posted by Jeff on March 10, 2020 at 9:41 am
    Good Morning Jon – in your article detailing your drop-ion Lithium replacement batteries, you mention in advance of installing new batteries:
    “On my Liberty there is a specific sequence required to shut down the electrical system and I followed that procedure.”
    Would you please share those critical steps here or in a PDF in the Articles Section? It would be most appreciated as nothing in any of my bus docs mention the proper procedure. THANK YOU!
    P. S. – I also have (two) OutBack brand inverters
    Fred F. replied 6 years, 8 months ago 6 Members · 6 Replies
  • Ronald
    March 10, 2020 at 10:24 am
    This is how I shut down my coach. Liberty probably has a couple of plastic engraved labels in your electric compartment, and on or near the Watchdog, and anything they say will over ride what I say below.
    First I shut off the two “battery charger” switches in the electric panel. Do not confuse them with the one labeled 24V charger because that is for the chassis batteries.
    Then I disconnected the Watchdog cable from the based of the Watchdog.
    Then I turned off the two house master switches in the electric bay, followed by the two inverter master switches.
    To power up the coach I reversed the sequence.
    On a previous coach when I made a house battery change the house switches (it was not a Crestron equipped coach) would not function so I rebooted the Allen Bradley system by turning it off with the key in the end unit and when it rebooted everything worked as intended. On this shutdown when I changed batteries the Crestron touch pads did not work, but the next day, after doing nothing they were working. I don’t have a clue why they didn’t work or why they resumed working. It must have been magic.
    March 10, 2020 at 11:45 am
    Thank you, Jon! Copied & pasted into a Word doc for future reference 🙂
    March 10, 2020 at 3:34 pm
    I make stuff up. Be afraid.
  • Roy
    March 10, 2020 at 7:58 pm
    Probably goes without saying: No shore power.
    March 11, 2020 at 7:39 am
    I did not disconnect my shore power. There was no need with what I had shut down, but disconnecting shore power adds another layer of safety.
  • Doug
    March 11, 2020 at 2:02 pm
    Lots of good advice here.
    But keep in mind that most if not all the advice is likely based on how the converter originally engineered, designed, and wired the coach. A previous owner or over zealous repair guy coulda tried to outsmart the original converter’s thinking and wired something in special that creates another layer of complexity.
    I don’t know how to find well intentioned, but short-sighted modifications … other than to make your shut-offs and then make sure what you thought was turned off actually is turned off.
