Battery maintain charger for chassis and generator
Posted by George on February 5, 2021 at 6:24 pmWhat brand battery maintenance charger do you have for the chassis (24 volt) and for the generator (12 volt) do you have?
What is good and bad selections?
Gerald replied 5 years, 9 months ago 6 Members · 6 Replies -
Battery minder Interesting product I have two of there units that work good. You can talk to a real person that knows their produce.
I have used Guest chargers on both chassis and generator batteries. I believe these will auto-disconnect when engine is running, but you should check that,
for 24 volt, you will need to buy a dual output charger and hook up in series to get 24 volts.
After my original 24v boat anchor charger fried my batteries I did some searching. I talked to the service manager at Night Train, a bus leasor for the music industry, they currently have 125 plus coaches. He told me he uses Dual Pro exclusively, so I purchased one and have been happy with it.
go to the NAPA store and use your discount. Have a 24 volt for 6 years works great and batteries are 6 yr old and still passing a load test.
Larry Nelson
2002 XLII VISION
2019 BUICK Envision
Hurricane, Utah
