Batteries
Here is question for Tom! When the bus is at home in the barn I keep it plugged in all the time, It has 2 newer Magnum inverter/chargers and four Lifeline 8D batteries. Should I discharge them a little bit some times or Not? The newer Magnum’s when it’s parked in barn I only use one of them to charge, the other one I turn off charger portion. They do very the volts from like around 12.7 volts to 13.5. Should I unplug and run some things to drop volts to around 12v ?? Or Not, We are going to be dry camping at the coast in Sept so I want to make sure it will work OK Thanks
