  • Bangor repair
    Posted by gary on September 11, 2013 at 8:46 pm
    Well on the way to the lobster rally I had a check egine light come on, and carried the coach over to the detroit dealer in bangor found out I had two problems needed a new EGR valve, and also found out by pressurizing the system that I had a aircharge cooler leaking, orderd it from New Jersey, came today also ordered all new air hose fittings and clamps for the CAC will be there in the morning at 7:00 AM for installation charger was leaking along the bottom core a little soap and water will tell you right quick if it is leaking, will update all on the works progress, Gary
    Dave replied 13 years, 2 months ago 3 Members · 2 Replies
  • Dave
    September 11, 2013 at 10:00 pm
    Also had the pleasure for the check engine light finding the code for EGR. I went with a rebuilt, has worked with-out any further problems.
    Did they tell you that there are 2 EGR valves on our engines ? My wallet is short about $1100 and change for that repair.
    With the check engine light on Sunday afternoon somewhere in Kentucky we were able to get a live person on Detroit Diesel help line in about 10 minutes.
    With the code determined by our on board pro- driver read out , we continued on our way as phone tech suggested.
    There are advantages in owning Prevost with help lines 24/7.
  • Merlin
    September 12, 2013 at 7:05 am
    Gary,
    Did you see Roger’s post about the CAC? Looks like they got some bad CAC’s that affect the H and XLII.
