  • Bad House Battery Question
    Posted by Timothy on July 22, 2018 at 1:44 pm
    Hi All,
    My name is Tim. Long time member having been introduced by Rudy. I am not a Prevost owner. I have a 2008 Country Coach Affinity and have a battery question.
    I have had one of my six 8D AGM house batteries go bad. It is overheating and has swelled from the top. Until I can replace that battery or all of them (I believe they were depleted while in for engine repair) can I bypass that one bad battery and continue with the remaining 5?
    Thank you.
    Tim
    Harry replied 8 years, 2 months ago 5 Members · 5 Replies
    July 22, 2018 at 4:37 pm
    It depends on how they are wired. If you have a 12V coach, you can just bypass the bad battery since they’d all be in parallel. It will leave your with 5/6th of your capacity.
    On a 24V coach, you’ll likely have three parallel strings of 2 batteries in series. You’ll have to disconnect both batteries in the string with the bad battery. This will leave you with only 2/3rds of your capacity.
    July 22, 2018 at 8:35 pm
    Let me know if you need batteries.
    Lifeline & Fullriver Batteries
  • Timothy
    July 24, 2018 at 6:05 pm
    Thank you. It is a 12v coach and they are wired in parallel. I bypassed the bad battery and all is good. This should allow me to get to my final destination and then I will begin the process of replacing all of them.
    Thanks again for the help.
    Tim
  • Harry
    July 24, 2018 at 6:07 pm
    Thanks, Tom. I will need a new set of six. Once I get settled, I will reach out to you. I will be in the middle of nowhere but will figure something out.
    Tim
    July 24, 2018 at 7:49 pm
    We ship to the middle of nowhere all the time.:)
