  • Axle weight ratings
    Posted by Dean on December 18, 2013 at 8:24 pm
    What are the axle weight ratings on a 02 XL2? (2003 conversion)
    Archived replied 12 years, 10 months ago 3 Members · 5 Replies
  • Dean
    December 18, 2013 at 8:55 pm
    There should be a sticker on back engine door when you open it at least on mine it is !!!!!!!!
    December 18, 2013 at 9:52 pm
    I knew there had to be one somewhere but hadn’t located it yet. I’ll look there tomorrow.
    December 18, 2013 at 10:02 pm
    Also check on the wall under the shifter panel beside your feet, should be a plackard from Prevost.
    December 19, 2013 at 4:32 am
    I think it should be 17,200 front,14,000 tag,22,500 drive.
    December 19, 2013 at 6:16 am
    Dean,
    because you likely have the CB enclosure on the lower panel beneath the shift buttons, look more towards the rear on that lower panel. The plate is probably hidden from view by the seat and on my last 2 coaches I had a very hard time seeing it, much less reading it because of the location. I think I ended up using my shop mirror to read the weights off it.
