  • Aux compressor ty in point
    Posted by Greg on January 19, 2014 at 9:56 pm
    is this Schroeder valve the location of you Ty in point for aux cmpressor?
    GregM
    Larry & Diane replied 12 years, 9 months ago 3 Members · 2 Replies
    January 20, 2014 at 7:19 am
    The connection point on my coaches was downstream from a protection valve and it was at a fitting that had a plastic label that was marked “converter”. Liberty used a manifold to distribut air to it’s systems, so it was the manifold that actually tied into the connection point, and the aux compressor fed into the manifold. The result is the same however.
    January 20, 2014 at 8:35 am
    That valve should fill your aux tank Greg. I assume the picture is the steering bay. I would drain the water seperator/filter often.
