    January 20, 2015 at 9:43 am
    Bryan
    Q: Why does anyone need to re-level while Parked?
    A:I hear that in California sometimes the ground moves.
  • joel
    January 20, 2015 at 12:08 pm
    With a 20 year old coach, that took a purposeful 3 year approach to zero everything out, I’m still looking for leak free. Until then I level with blocks for long stays in one place (football season) or set it down on the stops if the site is actually level, or add air periodically during short stays.
    The aux compressor is better starting the big noise maker, but, I ha be to watch the condensate produced.
    January 20, 2015 at 4:22 pm
    Good one, Dan. We did have a nice ride while parked at MCCC in Indio a couple of years back. I don’t remember whether we had to re-level.
    Eric, please post an update with the results of your compressor install.
    January 20, 2015 at 7:57 pm
    Hi Bryan,
    Still collecting my thoughts on which compressor to go with. Spent several more hours this morning locating
    and correcting two tiny leaks, because …….. even tiny leaks add up over time.
    More to follow.
    Eric
    January 20, 2015 at 8:23 pm
    Put a Gast in and fix all the leaks that’s the best bet , hope that helps
    February 1, 2015 at 11:25 pm
    Greetings PC Brothers and Sisters,
    Getting ready to install my new Aux
    Compressor. After many discussions with
    tech reps, and comparing specs, I decided to go with the GAST compressor. It was more expensive than other compressors,
    but I think a better value. Time will
    tell.
    One question before I install. I want to clean up some of the old airline,
    and there is a component I don’t recognize.
    No markings of any kind. From the
    compressor, the air goes through a (failed) check valve and then through this mystery
    component, then to the steering bay.
    What is this component?
    Thanks again for all the help and advice,
    February 2, 2015 at 6:03 am
    Any arrows or markings on it?
    While it looks a little large, my first reaction is it could be a check valve. I cannot think of any other device in the location you describe.
    February 2, 2015 at 6:47 am
    Good Morning Jon,
    No markings. Air is
    able to exit the line, so if it is a check valve, it is bad. My first inclination is to remove it – just another
    potential future leak. Filter?
  • Eric
    February 2, 2015 at 7:30 am
    Assuming there is only air going in and out, with no other connections it is probably a check valve.
    A filter or water trap would have a means of draining or servicing.
    The check valve downstream from the aux compressor needs to be far enough away so the check valve is not affected by the heat of compressed air so that might explain its location. If there was another check valve it is possible someone was unaware there already was one.
    February 2, 2015 at 10:31 am
    After looking at your picture the rectangular piece tied down with blue ties is a check valve. I’ve seen these installed in older applications. Not used often anymore due to collecting water thus spring inside weakens.
    February 2, 2015 at 12:55 pm
    Al brought up a good point. Observation if that is in effect it would be brass on brass and therefore to work correct would have to be installed vertically. Prob has a internal spring that has to be overcome by small pressure to open. Were notorious for getting small particles under seat. Just a thought– Bob
    February 2, 2015 at 1:35 pm
    Your first line off the compressor should be a loop or coil of sorts of copper tubing. It will help cool the air and help to minimise moisture.
    Call Liberty and ask Troy about it.
    JIM
    February 2, 2015 at 3:03 pm
    Thank you all very much.
    February 11, 2015 at 8:49 pm
    Gast compressor works great – quiet and powerful. Eliminated several defective devices during the install, including this ‘mystery’
    item. After cleaning it up, found it to
    be a very heavy and defective $60 rusted check valve.
    September 13, 2020 at 12:50 pm
    Evidently I left the breaker panel switch on the other day and came to the bus this morning with a compressor that was pulling serious AC amps and was very hot (I think it had tripped the panel breaker and when switched back on showed the high amps). I removed it for inspection, let it cool and it has decided to start working again, but I take the warning for what it is…
    I have a handy dandy California Air Tools 1HP on the shelf, I have had good luck with these in BBs, but in order to fit this in the hole behind the Cruisairs and under the batteries I’d have to re-imagine the stand the Gast sits on as the CAT is too tall relative to the Gast.
    Any other ideas short of a $700 Gast? My dream goal would be to air up the entire coach on 110VAC as I have done with some BBs but that probably entails some re-circuiting. Open to ideas….
Page 2 of 3
