  • Aux Compressor Replacement Options
    Posted by Eric on January 17, 2015 at 6:40 pm
    My Aux Compressor (non-original model) is dead. Motor works, but the loud loud loud compressor
    is caput. Jeff, very kindly gave me an
    original replacement make/model – GAST / 5KA94.
    Because of sticker shock, I went looking for a less expensive
    alternative. The alternative compressor needs
    to be comparable to the original (quiet, effective, durable).
    Below are the specs. for the suggested replacement (GAST / 5KA94) and a
    possible substitute (California Air Tools / CJL1002). The CJL1002 promises 3000 hours, no such number
    is listed for the 5KA94 – but I expect it is at least equal. If I go with the CJL1002, I will have to
    convert the 220 v bus compressor outlet to 110 V. Otherwise, I don’t see any issues. Please let me know your thoughts.
    Eric
    GAST Model 5KA94
    Cost $ 1,037
    HP 1/2
    Voltage115/230 VAC Hz 60 Phase1
    Full Load Amps 12/6
    Thermal Protection
    Sound Rating75
    Oil-Less
    Valve Stainless Steel
    PSI Cont./Int. 50/50 Free
    Air CFM @ 0 PSI 4.5Free Air, CFM @ 40 PSI 3.1Free Air and CFM @ 50 PSI 3 Max.
    Length13-1/6″Overall Width12″Overall Height8-7/8″Cylinder
    California Air Tools Model CJL1002
    Cost
    $ 190
    1.0 HP (Rated / Running) 2.0 HP (Peak) Motor
    Volts – 110
    Amp draw – 7.6 Amps
    Thermal overload protector
    60 Decibels
    Oil-Less
    Hardware Stainless steel
    3000 Hour Pump Life
    120 PSI Maximum
    CFM at 40 psi 3.80 and CFM at 90 psi 2.35
    Air Filter and Capacitor
    Overall Height – Top to Bottom: 9.
    5
    Overall Width – Side to Side: 5
    Overall Depth – Front to Back: 10.5
    Overall Product Weight: 23
    DON replied 6 years, 2 months ago 14 Members · 32 Replies
  • 32 Replies
    January 18, 2015 at 7:30 am
    The specs don’t make sense. The current draw on the greater rated HP compressor is less than that of the compressor with half the HP.
    So my first reaction would be to apply the sniff test to the other claims. Usually when a company is willing to mislead on one piece of data, the rest of the data is suspect.
    Having said that however, my brain would put a purchasing decision on the back burner until I had the coach relatively leak free. When an aux compressor wears out it usually is due to excessive running. It did not state what the duty cycle was on the compressors being considered, but it is not unusual if the leaks are large to exceed the rating and significantly shorten the life of the compressor. The engine compressor is more robust, but it has a 25% duty cycle so keeping the coach pneumatic system relatively leak free pays dividends.
    January 18, 2015 at 8:11 am
    I will repeat what Jon says …
    This is a very, very profound statement. New coach owners and those veteran coach owners who find his statement enlightening, this is very important.
    January 18, 2015 at 8:53 am
    My coach did not have an aux air compresor. I installed this one, cheap, 12 VDC, 100% duty cycle. Noise will depend on the mounting.
    http://www.amazon.com/gp/product/B000FQ78VI/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I only have about 4 loads on the aux, floor slide, door lock, air horn, one other but, i still need to find some leaks. Mine will run about every 12 hours when parked. It has enough pressure I can re-level but the volumetric flow is low enough it takes a long time to do so.
  • jack
    January 18, 2015 at 12:53 pm
    I installed a 100% duty cycle compressor from Viair (12V). It has been flawless. Viair 450c, 150psi, about $200.
    http://www.viaircorp.com/
    January 18, 2015 at 1:15 pm
    Good advice – thank you.
    The new compressor is the final step.
    I have already resolved many of the leaks. One of the major leaks was the old compressor,
    significant leaks at the head and fittings, which additionally revealed the need
    to install a new check valve.
    I noticed the non-standard compressor I removed did not have
    a pressure switch (on/off) installed, but rather just used the bus pressure
    switch. Was this installation
    correct? I would feel better if the
    compressor also had a pressure switch – at least on the high side.
  • jack
    January 18, 2015 at 6:05 pm
    I set mine up with its own pressure switch. You can get them with various on-off pressure settings. I think mine is 85-105 but if never want the option to re-level I’d choose something lower.
    January 18, 2015 at 6:14 pm
    the way liberty wired that has its own pressure switch in front run box
  • Les
    January 18, 2015 at 8:10 pm
    Graingers has lots of repair parts if the electric motor is good they might have parts for the compressor that might be a better option than replacing and re wiring that area.
    January 18, 2015 at 11:01 pm
    I considered fixing the aftermarket compressor, but given how noisey it is, and its low output, I think a new compressor is the best option.
    I would have rebuilt the orighinal GAST compressor, but it was long gone before I bought the bus. Oh well …
  • jack
    January 18, 2015 at 11:52 pm
    It really surprises me that they would wire it off a 220v circuit.
  • jack
    January 19, 2015 at 5:23 am
    it’s 120v
    January 19, 2015 at 5:43 am
    My mistake, I thought it was 220 volts. The compressor I just removed has this type of plug:
    I will get my Fluke meter out and see what is going on.
    January 20, 2015 at 1:13 am
    Eric, when you test you should find that twistlock plug is 120v. The twist just keeps it plugged in.
    I’m in the same place as you, compressor-wise. The Jun-Air (now Gast, I guess) compressor was removed from my bus before I got it. That California Air model you mentioned has been in my cart in Amazon for months. It is well reviewed and supposedly very quiet. I only need aux air to operate my entrance door while parked so it hasn’t been a high priority. I get about 20 cycles before we have to start pushing it manually.
    Why does anyone need to re-level while parked? If the coach is leveled and the leveling system is shut off, doesn’t it just hold air unless the bags themselves are leaking? Either I’m lucky or I never stay in the same place long enough to have to re-level.
  • Eric
    January 20, 2015 at 6:33 am
    Bryan.
    You hit a sore spot with the question about re-leveling. I am not familiar with MCI so I cannot draw a comparison, but I can tell you that as Prevost has evolved an 8 air bag suspension has gotten increasingly complex. The basic underlying principle of the system remains but even that has changed over the years.
    Our first coach had 8 air bags, three ride height valves and about 8 Prevost installed Norgren valves to control the ride height or leveling. All fittings were compression.
    Fast forward to today……….The coach now has more Norgren valves, each air bag location also has a ping tank, and all fittings are push in fittings which age and leak. So because of the changes we not only have almost double the leak points because of the changes to the systems, we have fittings that do have a tendency to leak due to age. At the age of your coach an owner is definitely going to be chasing leaks.
    Having said that however once a coach has been made “leak free” by virtue of the replacement of fittings, old valves and old air bags it will have years of leak free service.
  • gary
    January 20, 2015 at 7:44 am
    Yes – you and Jeff are correct. It is 120v.
    The unusual plug fooled me. I am
    humbled every time I undertake a project.
    Thanks to each of you for sharing your knowledge and experience. Even though there is a steep learning curve,
    still lots of fun.
    Eric
Page 1 of 3
