  • Aux air pump is not running
    Posted by Tony on March 8, 2022 at 6:35 pm
    My aux air pump is not working on my H3 Van Tarr is there a overload or breaker? Is it 12/24 volts or 110 ac? Any idea will be appreciated
    thx
    Doug replied 4 years, 7 months ago 4 Members · 3 Replies
  • Michael
    March 8, 2022 at 6:41 pm
    You are so close to ETLC that a call to them might be in order. If you have a problem with your coach, they can fix it!
    I am not familiar with your conversion but it’s most likely that the pump is 120V and that there is a reset button on the air compressor itself if you have not yet checked that.
    Mike Harper
    2004 Marathon XLII
    March 8, 2022 at 10:10 pm
    I haven’t but will. Have used Jeff many times
  • Doug
    March 9, 2022 at 5:44 pm
    The aux compressor in our Liberty is 120VAC and is controlled by a dedicated 120VAC circuit breaker on the main electrical panel. If is 120VAC, it might have overload protection with a button to push if you can find the compressor. Good luck!
