Aux Air Compressor Not coming on
Posted by Pat & Jan on January 25, 2015 at 11:21 amPicked up our 03 Liberty from Stuart and made it to TGO safely. This morning noticed pocket doors and gray water dump valve and front door slide not working. I have no Aux air pressure. Can not get aux air pump to come on. I have reset panel breaker to no avail
21 Ram 1500 EcoDiesel 4x4Larry & Diane replied 11 years, 9 months ago 7 Members · 8 Replies -
Pat,
I live at TGO and could come and take a look at your peoblem. Not to much Liberty knowledge but can try to do some trouble shooting.
Let me know what site you are on and I will come over if you want some help.
Way to go Andre.. Hope you and Ann will be at Bella Terra…
Also hope you can make it Pat !!
Diane
The aux compressor is controlled by the circuit breaker in the electric panel, and assuming that breaker is passing power to the compressor the only other switching device is the pressure switch which on mine looks like a water well pump switch in the steer comparment.
My guess is the pressure switch, which if bad is an easy replacement. Relatively cheap at Lowes or Home Depot.
Some pressure switches have a little red handle that is the on-off switch,the pressure switch can be found in the steering bay which is just under the drivers seat and the switch on mine is located on the rear wall.
I agree with posts. If the breaker at the load center is on and not tripping the breaker, go to the pressure switch in front run box area. Let me know if you have a problem with finding it.
Pat found the presuure switch and tapped it with a screwdriver and it turned on te compressor for a few seconds. He is going to look for a new switch in the morning. It sounds like he has a bad AUX air leak and he will be looking for that also. He has my number if he needs help. I will check on him tomorrow.
Get him a spray bottle and a jug of Dawn liquid soap. Sounds like he will need it!
Thanks forr great advice. Off to get the parts this morning and then GET TO WORK.
