Auto start box??
Posted by Art on August 2, 2018 at 8:56 pmIs this a old school auto start box?? Switch marked Monitor ? Where is monitor? How does this box work? Or should unplug and remove?
Darrell replied 8 years, 2 months ago 6 Members · 6 Replies -
I am sure someone knows the answer to your question, but if my coach had that my first step would be to see if the box switches would actually start the generator.
If it did then the next thing I would do is put the switch in the monitor position and pull the house battery voltage down by loading them up to see if the generator would start at some lower votage. I would not go below around 11.5 volts.
I interpret monitor not to suggest a computer or TV screen, but to “monitor” a situation such as to monitor the voltage of the house batteries.
As I recall the auto start switch is on the dash. So the toggle switch is usually in the monitor position at the control unit. Then you have the option of being able to auto start for low battery voltage or low ac voltage.
Test the system and verify operation before starting to remove anything.
Art,
I just sent you an email with some Gencon Autostart information.
1-Frequently asked questions.
2-Gencon input-output connection diagram.
3-Gencon wiring diagram.
I would post them here but they are in .DOC and .PDF format.
I don’t think I can post those formats here?
Tim T. if you cannot post or upload the information send it to me and I will make sure it either becomes part of this thread or an article available for all to reference. My email is active.
Files sent.
Could I have posted them as a reference article?
Thanks!!
Yes, you could have made them available as an article.
1999 XLV X-6872, liberty #440
