Auto-fill solenoid
On our first trip out with the coach,while in a RV park connected to their water, I deceided to use the auto fill since our tank was running low. I pressed the switch on the dash and it activated the fill solenoid. I didn’t want to fill the tank so after about five minutes I pressed the dash switch to turn it off. Nothing happened,tank still filling. I pressed the switch in the “water bay” and still nothing happened. To stop the water,I disconnected the power wire at the solenoid. I suspect the relay is stuck/bad. After two hours of searching, I located the relay ( I think) behind a panel next to the hot water tanks and adjacent to the refrig water filter. Had to order a relay since local parts stores didn’t have one available. Now I am wondering if I could have a bad switch? If one switch was bad,would the second switch deactivate the relay? Just thinking ahead if the relay doesn’t fix it. The dash switch stays lighted all the time now. Any thoughts?
Michael
