  • Atwood Water Heater’s
    Posted by Tim on April 2, 2017 at 4:47 pm
    In my Marathon, like many others, I have two 10.5 gal Atwood WH’s. This morning I noticed we ran out of hot water at around 10-minutes of showering.
    I let the WH re-heat thru the 110V until the 110v shut-off. I then checked, thru the two pressure relief valves outside in the waterbaby, the hot water temp’s. The top WH was very hot. The bottom WH was cold.
    I can’t remember if this is how they are supposed to work, wherein the top WH remains hot and the bottom WH only ignites after the top WH runs short of hot water, or whether they should both be hot at all times.
    I will say that I turned on the 12v webasto for around 20 minutes, and the bottom WH did get warm, but not nearly as hot as the top WH. I would think it should work the same as the 110V element.
    Any opinions?
    Archived replied 8 years, 1 month ago 14 Members · 24 Replies
  • 24 Replies
    April 2, 2017 at 4:53 pm
    They should both be hot Jake.
    Later
    bv
    April 2, 2017 at 4:55 pm
    Would there be a separate fuse that could have tripped and is there a 110V element for each WH?
  • Rudy
    April 2, 2017 at 5:16 pm
    It’s a seperate electric element. One of mine went 4 years ago, easy fix on mine. Both are stacked inside plumbing door on mine, on your H, I don’t know but if you can touch it shouldn’t be to bad.
    Later
    bv
    April 2, 2017 at 5:17 pm
    Tim, my coach is a CC but it has the same H2O heaters and a breaker for each.
    April 2, 2017 at 5:26 pm
    Wishful thinking, you have a 12v breaker and a 110v breaker.
    Unless our’s are so different in build years.
    Later
    bv
    April 2, 2017 at 5:34 pm
    My Marathon manual says I have a breaker for each WH in the waterbay.
    I know I have the A/C breaker inside the coach for the WH’s to operate, but any idea where the breakers are in the waterbay where the WH’s are located? Maybe one tripped. Both heating elements are new.
  • Dan
    April 2, 2017 at 5:36 pm
    you need somebody with an H, I’m outta here.
    Later
    bv
    April 2, 2017 at 7:08 pm
    Check the thermostats on the heater itself. I had one that would sometimes pop for no apparant reason. Reset it and all was good again. If your a/c breakers are good, then it must either be that or the element.
    April 2, 2017 at 7:24 pm
    Tim,
    Mine are on the bulkhead in 2nd bay, bunch of breakers in there you may not have noticed.
    April 2, 2017 at 7:47 pm
    Located my “Waterbay Module” in my second bay, passenger side, on the bulkhead. I took off the lid and found the following fuses/relays. I haven’t seen these type before. The one with the red light is labeled “RGS”, but it doesn’t look like a breaker you can reset.
    Is this what you were referring to?
    April 3, 2017 at 7:10 am
    My mistake Tim, I looked this morning since I’m now at the bus. My water heater breaker is in the bedroom and is a single 20 amp breaker. The additional breaker box I was referring to in the bay looks like this:
  • Ted
    April 3, 2017 at 7:25 am
    It doesn’t look like my bottom WH is getting electricity. Is there a re-set button on one of the WH’s that may have popped?
    April 3, 2017 at 9:44 am
    I’ll take a look, but it’s monsoon season here today in Vonore.
    The good news is none of my slide seals are leaking.
    April 3, 2017 at 10:22 am
    No problem Tom,
    Infound the reset button, but it wasn’t tripped. Looks like I’m not getting power to the bottom unit so it may be a bad thermostat.
  • Alvie
    April 3, 2017 at 10:44 am
    Tim,
    Did you find the reset button mounted on the top water heater? It is behind a chrome panel. After it happened the second time, I left the cover off so I can just reach in to push the red button.
