Aqua-Hot vs. Wabasto
Hello Folks,
As some of you know, I’ve been researching a converter to have a new bus built. Some of them offer Aqua-Hot and some offer Wabasto. I’m aware that Aqua-Hot has a Wabasto inside.
We currently have an Aqua-Hot and have been extremely pleased with it’s operation. We have the Aqua-Hot that has the two stage electric feature (110 and HI). It allows me to use the Aqua-Hot system electrically if the temps are above 40-45 degrees to heat the coach. We also have the engine recirculating button to heat the engine by the AH.
The AH and Wabasto are SO similiar and it seems to me the only real difference is that the AH uses it’s own antifreeze and not the antifreeze from the engine like the Wasbasto.
I’m leaning towards wanting another AH system and here’s why. Recently, I had a coolant box start leaking attached to my Cummins. If I needed heat through a Wabasto, it would worsen the problem causing it to leak while parked.
Now, if my AH developed a leak, it would not effect the engine operation of the coach, just the AH and vice-versa.
Am I correct that a coolant leak in the engine system would make the Wabasto useless in a situation like that?
Thank you,
MM.
