  • Aqua hot rebuild
    Posted by Peter on July 15, 2013 at 7:25 pm
    I rebuilt my aqua hot today everything except the tank new everything bearings where bad wires bad flame detector bad motor bad burner tube bad fuel nozzle bad electrodes bad mixing valve bad mostly all caused by bad bearings in motor took 3 hours all good now hot water for ever May have left some stuff out got tried of typing all good now. It all started with Luke warm water after awhile in shower and black soot on ground after sitting in one spot for a couple days mixing valve would not turn freely also The control box was already new and the fuel pump was good also Only thing that I reused was the plastic case and cast case everything inside new
    Hector replied 13 years, 3 months ago 3 Members · 2 Replies
    July 16, 2013 at 7:00 am
    Peter,
    Remember, I had it turned off at the engine, so if you need engine preheat or hot water while traveliing, turn those valves back on. I leave my Liberty hot water tank turned off as well to keep from getting scalded.
    You may still have some good parts, the pump, nozzle, flame detector, banjo fittings and control box were all new.
  • Hector
    July 16, 2013 at 7:36 am
    Banjo fittings where good reused them the pump was good too flame detector bad to much heat on it nozzle I just put new one valves r turned on for hot water from motor bearings where most of the cause burner tube meted inside bearings slowed motor down flame was not being push hard enough flame detector was all dis colored too all good to go now motor looked like the original one I put updated one on I like no problems When I get done with the coach everything will be new if Trina will let me ha ha can’t wait to see you guys
