  • Antifreeze Petcock on Generator Block ?
    Posted by Archived on November 16, 2012 at 9:57 am
    I have a 20K Powertech Generator in My Liberty. And had a small oil leak around the Oil pressure sending unit. Which I fixed yesterday. And while I had it pulled out and running. I noticed that on the side of the block there is a Petcock valve that has a “T” on top of it and a Spring on the bottom. And was dripping Anti-Freeze very slowly. When You turn the T either way. Antifreeze will come out the front of it. So the spring on the bottom keeps pressure on the valve keeping it closed. And must be getting weak. There is a couple of fittings / Adapters I guess between the block and the actual valve. I am thinking about removing the valve and putting a brass plug in to seal it. Either that or Shim the spring to increase the pressure of it. This valve must be there to drain the block completly since the Radiator for the unit is in another bay.
    Has anyone else had a problem with this valve ? What is the proper name for it ?
    Thanks,
    Rocky
    John replied 13 years, 11 months ago 3 Members · 2 Replies
    November 17, 2012 at 11:04 am
    Hi Rocky, I have a 17.5k powertech that had the same “anti-freeze” leaking valve that you are refering to. It was easy to replace it and that was that. I dont’ think you should plug it.
  • Charles
    November 17, 2012 at 4:41 pm
