Antifreeze circulation pump?
Installed the new water solenoid valve and looking at circ motor right next to it, it says 24DCV and it only has 12DCv going to it. If you look at schematics in picture from motor backwards junction #109 wire C23 then goes through relay R35 it activated by switch but going farther to breaker CB73 then to 24v supply But it’s not 24v at CB73 it’s 12v,pump runs but slow, Nothing looks out of place what do you think?? You can see where it hit’s the 24V junction not sure from there it says 24v Hot wire from FR JCT Box Jct 112 see pg 1
