  • Another OTR Air Question???
    Posted by Archived on June 29, 2017 at 9:02 am
    On a
    coach equipped with Prevost installed OTR (whole bus air) air
    conditioning, will there be another smaller and separate compressor
    for the “dash” (or drivers) air conditioning or does it use the
    same large one for dash air conditioning?
    Corey replied 9 years, 4 months ago 6 Members · 9 Replies
  • 9 Replies
  • Will
    June 29, 2017 at 11:26 am
    Uses the same compressor and you can select dash, coach or both. The dash controls are different on the later models, Jon will pick this up I’m sure.
    June 29, 2017 at 12:01 pm
    Tim, my 96 dash air uses the same large Prevost/Carrier OTR compressor as the rest of the bus. It has a separate dash circuit(freon on/off solenoid, evaporator, expansion valve, fan, etc) that Ts off the main circuit.
    I had to replace the dash circuit expansion valve when we bought our bus.
    June 29, 2017 at 1:37 pm
    On mine the compressor will not be activated unless the entire coach and dash are selected,and if I turn off the dash it also turns off the coach.So my answer is you cannot just run the dash,the system will not allow that.
    June 29, 2017 at 3:22 pm
    What Jack said is correct. When I run the dash only it is because I just want a little heat or some air flow. I cannot get A/C unless the entire system is on.
  • Kent
    June 29, 2017 at 3:47 pm
    Just knowing what to look for helps.
    Thanks to all for your responses!
  • victor
    June 29, 2017 at 5:05 pm
    I was incorrect, I forgot my 01 Liberty would not run the dash air unless the coach air was operating.
    June 29, 2017 at 5:24 pm
    Mine too is like Tom said, dash won’t blow cold unless the main cabin air is on.
    June 29, 2017 at 9:13 pm
    Don said, “Mine too is like Tom said, dash won’t blow cold unless the main cabin air is on.” Other concurred.
    Huh. Didn’t know that. Will have to play with mine.
    If the OP is worried about fuel consumption with the big compressor running to just cool those up front, the big Carrier compressor has six cylinders and based on A/C load and demand will engage two, four, or all six cylinders. I thought that was pretty slick when Jeff Rowe explained it to me.
    June 30, 2017 at 12:56 pm
    Both definitely have to be on for the system to work properly.
