  • Ample Power V3 Regulator
    Posted by Edward & Sandy on July 9, 2015 at 2:27 pm
    This 2002 Royale has a Ample Power V3 Smart ? 12v house regulator. It wont pick up charging after a short time after engine start. Running down the road the batteries slowley run down using ihe center A/C, finally tripping out the inverter, low voltage. If I disconnct shore power for a short while, start the engine the Amp gauge will ramp up to 100 A then slowley recede to 0. But running the center A/C does not direct the regulstor to ramp up charging.
    Anyone with this regulator and ideas
    Thanks in advance
    Ed
    Archived replied 11 years, 4 months ago 2 Members · 1 Reply
  • 1 Reply
    July 9, 2015 at 7:43 pm
    Sounds like the regulator is toast. When it starts to charge, what voltage are you getting at the house batteries?
