  • Alternator not charging
    Posted by Ken on November 15, 2018 at 10:06 pm
    My alternator suddenly stopped charging, the lifeline next step alternator regulator has a error light flashing. Has anyone had this experience or know what causes it.
    Ken
    Walter replied 7 years, 11 months ago 5 Members · 5 Replies
    November 21, 2018 at 10:55 am
    How do I create a Post? I am using Chrome and do not see a Create thread anywhere.
  • joel
    November 21, 2018 at 11:42 am
    Apex,
    Go to FORUMS
    Select topic, ie ELECTRICAL, GENERAL, etc.
    Scroll to bottom
    NEW POST Button located at bottom
  • Walter
    November 21, 2018 at 1:55 pm
    Ken, nobody is ignoring you, just surprised nobody has responded.
    Did you measure alternator output to verify if it not charging?
    Did you then run a jumper to the field terminal from the 24V battery positive to make sure the alternator is functioning. Pay close attention because when you do that the output voltage is unregulated and you need to pull the jumper if the voltage starts to go up past 28V.
    If the alternator does put out voltage with the jumper attached the regulator is bad. If not the probable issue is the alternator. Obviously you need to check all connections.
    November 23, 2018 at 11:06 am
    Thank you Jon. I will check this out
    Ken
    November 27, 2018 at 5:10 am
    http://dublerfamily.com/Regina_oceani/Manuals/Electrical/next%20step%20regulator.pdf
    This may help, we have been able to replace those still in the past..
