  • Alternator Issue
    Posted by atanas on November 29, 2018 at 7:56 am
    Ok back at on different Bus. same type 09 X3 with dual bosch alternator setup. on dash MFD i have active code for Open circuit on alternator 1. so far I have checked all voltages going to each alternator on the 3 pin connector to each alt.
    Alt 1- wire 1 27.8v, wire 2 27.9 wire 3 12.6v as it should be
    alt 2 same results with Key ON engine OFF
    Now Key ON engine running
    I have a voltage of 28.4 on alt 1 and 28.5v and alt 2, which is telling me both are charging.
    Now on a another job, i was asked by a Prevost Rep to check Key ON, Engine Running voltage on Module 49 wire 25A1 and 25A2. i have 28.6v wire 25A2, but nothing on 25A1. which is telling me i have no output I think?
    i am trying to figure out what module 49 does? on the panel board it only says module 49- I/O A. thats it
    atanas replied 7 years, 9 months ago 1 Member · 0 Replies
